K-Cars The generation of cars that will forever live in infamy. The glorious K-car.
86 Aries Defrost problem
Old Jan 11, 2005 | 11:05 AM
simwiz's Avatar
simwiz
Default 86 Aries Defrost problem
I have a problem with my car that has been there ever since I bought it. No matter what button I push, the heater won't change where it blows the air out of the vents. It is stuck blowing 90 percent on the floor and a little on the windshield. The fan control works, as does the heat control. I was told the air controls are vaccum controlled? I can't find any vaccum leaks in the dash.
It is -25 C where I live, so I need this to work, how do I change this manually?
Thanx,
Ian
Old Jan 17, 2005 | 11:53 AM
simwiz's Avatar
simwiz
Default RE: 86 Aries Defrost problem
I would really appreciate some help. It is very cold!
Thanx,
Ian
Old Jan 18, 2005 | 01:19 AM
87Indy500's Avatar
87Indy500
Does you car have A/C?
If it is, it sounds like that vacuum line or the actuator needs to be looked at. The heater control uses vac. to switch location on an A/C car. I'm not sure if a non-A/C car is the same or not????
Old Jan 19, 2005 | 12:34 PM
simwiz's Avatar
simwiz
I think it probably needs replacing, but I don't want to pull my whole dash apart hunting for a vacuum leak. Is there a way I can just manually move the actuator to set it to defrost all the time? Also, where is the actuator located?
Thanx,
Ian
Old Jan 27, 2005 | 12:22 AM
GTCandGTSturbo's Avatar
GTCandGTSturbo
Check under your hood. There should be two vac lines going into the firewall to the left and down from the heater hoses. A white one and a black one. Make sure these are attached to something. Its odd, because defrost is the default position if something goes wrong - its a safety thing.
Old Jan 27, 2005 | 12:23 AM
GTCandGTSturbo
Oh, and its the same for both AC and non AC cars. Only the auto climate controled cars used a slightly differnt method.
