I need help on my 2.5 turbo shadow
i just bought a 2.5 turbo shadow did the head gasket. im haveing trouble on putting the vaccume line back together with the turbo its not building boost like it should. most of the vaccume lines werent right in the first place so if anybody can help me with pictures or a digram that would be helpful thanks for any info you give me.
If you look under the hood, I think its on the drivers side, you'll see a label you might have to wipe it off with a rag, DO NOT USE SOLVENTS!!!! solvents will remove all the print on it. This should be your vacuum hose routing diagram. Unfortunately the shop manual guy was not at the show I just returned from this year, I was going to pick up repair manuals for both the P and K cars. Let me know how you make out I'll do some research for you if needed.
