K-Cars The generation of cars that will forever live in infamy. The glorious K-car.
Easy way to drop a shadow
Old Apr 4, 2005 | 03:19 AM
Bassboy's Avatar
Bassboy
Default Easy way to drop a shadow
Anyone have any suggestions aside from cutting the springs to lower a 93 shadow? Im putting new shocks/struts on the car soon and was thinking about lowering it but cant find drop springs or anything for it.
Old Apr 4, 2005 | 03:58 AM
casper's Avatar
casper
Default RE: Easy way to drop a shadow
Get into the sunlight, that will get rid of the shadow. But anyways, there should be some lowering kits out there. Try ebay.
Old Apr 4, 2005 | 02:28 PM
SHADOWES's Avatar
SHADOWES
eibach makes a set of 1" drop springs. search around. they're about $250 new.
Old Apr 8, 2005 | 03:36 AM
Spaceship1's Avatar
Spaceship1
Good luck, cutting the springs isnt wise, kind of a personal issue, cause i am a firefighter, and the dumb bastard that has to cut you out of the car when you wreck. So, i dont like the spring cutting idea. Try measuring them out and seein if you can get springs to fit another vehicle that match, thats about the only idea i got.
Old Apr 10, 2005 | 05:19 PM
SHADOWES's Avatar
SHADOWES
If you wanted to go dirt cheap you could get the spring compressers at auto zone or advance auto for about $4.50 per set...it'll only give you maybe a one inch drop max. That's what I did until I can get the eibach springs and body kit for my shadow. They also make a dynomax catback for it too. It runs about $90 with muffler.
Old May 24, 2006 | 04:05 AM
jmja9281's Avatar
jmja9281
you could also try to heat the springs just make sure you are on level ground.
