Does anyone know where I can obtain a list of the fault codes for this car. I came across three fault codes and don't know how to break them down (14, 22, & 31).
Thanks, that is exactually what I was looking for. Here's another question for you. The car is a 1987 Horizon with 53K on it. It was involved in a front end colision. I replace the front end and am currently trying to sort out these idling issues. The car starts up great. The idle seems to jump up rather high, and seems to present a slight miss. When I kick the idle down and try to shift the car into gear (automatic) the car dies. If i really let her warm up (full operating temp.) the problem is not as bad, but still has a miss (kind of a stutter). So far I have replaces the plugs, wires, cap, coolant sensor, fan relay, oxygen sensor. I also had to replace the computer, due to damage from the accident.
change the pick up in the distibutor if it was wreck sometimes these get jarred enough to break or get damaged they are in the front of engine the first place to accept damage
