K-Cars The generation of cars that will forever live in infamy. The glorious K-car.
Any problems mixing brands of Dexron III transmission oil. From one brand to another?
Old Feb 23, 2010 | 06:12 PM
1986Dodge600's Avatar
1986Dodge600
Default Any problems mixing brands of Dexron III transmission oil. From one brand to another?
Like if u ar just gonna drop the pan & do a fluid & filter service & drain whatever fluid comes out. Then put new back in.
Is it a problem just say you had Shell brand Dexron III Transmission Fluid in ur car & you were to buy Castrol Dexron III transmission fluid is that a problem mixing the brands even tho they are both Dexron III. As long as they are both conventional oil based?
Specifically the transmission i'm wondering about is a 1986 Torqueflite 3spd Automatic out of a K-Car.
Old Feb 23, 2010 | 06:40 PM
rare aries's Avatar
rare aries
Keeper of the Ks
You should be OK as long as they are both Dex III. I never had a car come back to the shop after I topped off the trans fluid, and used what we had and not knowing what brand was already in the trans.
