K-Cars The generation of cars that will forever live in infamy. The glorious K-car.
1989 Dodge Shadow any input appreciated
Old Jun 22, 2010 | 07:28 PM
torreyj's Avatar
torreyj
Exclamation 1989 Dodge Shadow any input appreciated
Ok, here's the story. I bought this Shadow 2.2 tbi about 6 months ago and it has been a great car for me up until now. I have done a lot of work to it(p/s hoses, brakes, rotors, hubs, half shafts, timing belt, water pump, valve cover gasket, crankshaft seal...blah blah). In any case, this car has run great for me up until about a week ago. I started noticing some stumbling when driving not a lot, it almost felt like it was shifting gears back and forth, but it was the engine, then it started to idle rough, but would still drive fine, then it started running pretty bad and it barely driveable now?
I have replaced the O2, MAP, TPS, checked all vacuum lines replaced rotor, cap, coil, checked compression. with no avail, it will barely run now and it seems almost like it is missing. I mean you can get it to go but it takes some work.
If anyone has any ideas or insight into this problem it would be greatly appreciated. I guess what i'm baffled at is that it would go from running great(the only problem ever was that when i first started it it might rev high but then idle fine) to idle rough to now barely functioning.? any idea? thanks. Torrey
Old Jul 6, 2010 | 02:36 AM
mrfarrell's Avatar
mrfarrell
fuel filter?
Old Jul 6, 2010 | 11:49 AM
sapporo's Avatar
sapporo
fuel pump?
distributor pickup?
head gasket?
water in the gas?
