K-Cars The generation of cars that will forever live in infamy. The glorious K-car.
Keys locked in trunk. Help?
Old Nov 28, 2010 | 01:02 AM
xochitl's Avatar
xochitl
Default Keys locked in trunk. Help?
HEEEEELP! I locked my only set of keys to my car in the trunk! It's an '83 dodge aeries. Can someone PLEASE tell me how to remove the back seat or if there is another way to gain access to the trunk!! I'm a broke college student so I can't put down the money for a locksmith.
Old Nov 28, 2010 | 07:04 AM
sapporo's Avatar
sapporo
take out lower cushion, then remove back cushion.
Old Nov 28, 2010 | 09:31 AM
rare aries's Avatar
rare aries
Keeper of the Ks
The bottom cushion comes out one of two ways, (its been about 20 years since I was in a first gen K, so I dont remember which way you do it) The first way is push down on the left and right side at the same time push the cushion toward the back,then give a sharp upward pull, the other way is there may be a bracket under the left and right side of the cushion with a screw visible on the floor, remove each screw and pull the seat up. To remove the back rest there will be two screws on the left and right at the bottom, remove them and pull the back rest toward you, there may be a sheet of paper between the back rest and the trunk if this tears dont worry.
