K-Cars The generation of cars that will forever live in infamy. The glorious K-car.
Where is the turn signal flasher?
Old Jun 22, 2005 | 12:05 AM
93blendor's Avatar
93blendor
Default Where is the turn signal flasher?
Hello,
I have a 93 Shadow. Here's the problem - the turn signal does not blink, either left or right side. The indicator arrow stays on solid. All bulbs are working. All lights blink correctly when the hazard switch is pressed.
The Haynes manual shows two separate flashers on a gray block behind the fuse block. While looking in the car, there is only one flasher (hazard) and no connection for a the turn signal. The other components on that block are the horn relay and keylight timer delay.
Is there a separate turn signal flasher? Where is it located?
Many Thanks.
Chris
Old Jun 23, 2005 | 12:21 AM
Bassboy's Avatar
Bassboy
Default RE: Where is the turn signal flasher?
What ya need to do is take out the bezel around the radio/heater controls, above the heater controls mounted to a peice of metal you will find you turn signal flash unit . Its pretty easy to find once you know where to look, I know what you mean about the other 2 in the gray block I started flippin out after payin 10 bux (got the good one) for a flash unit and it didnt work lol. If you still cant find it lemme know and I will take a picture for ya.
