K-Cars The generation of cars that will forever live in infamy. The glorious K-car.
2.2L Turbo
Old Mar 18, 2006 | 11:50 AM
Dodge_Ram_3500's Avatar
Dodge_Ram_3500
Default 2.2L Turbo
My Shadow has the 2.2Litre engine in it, with no turbo, but my friend owns an 85' New Yorker, with a 2.2Litre turbo engine.
Would a turbo off that same engine fit onto my 93' Shadow's 2.2Litre? Thanks
Old Mar 18, 2006 | 02:17 PM
tengle2006's Avatar
tengle2006
Default RE: 2.2L Turbo
With some modifications, probably.
The question is, though, would it be cheaper (and easier) to just go looking for a 2.2T that's in decent shape and rebuild it then drop it in than to go through all the labor and expense of changing your 2.2n/t over?
That's for you to decide.
Old Mar 18, 2006 | 03:25 PM
Bassboy's Avatar
Bassboy
I would find it easiest to find a totalled shadow (perferbly rear end totalled) so that you have the ECU and wiring harness aswell as the motor. Either that or find a cheap one and rebuild the motor in that but aswell you will have the harness and ECU. Which are 2 things you will also need, Also if I'm not mistaken you will need the fuel pump from a turbo.
Old Mar 18, 2006 | 06:36 PM
Dodge_Ram_3500
Ok. Thanks fellas for the help and info, I dunno if I'll ever actually put in a turbo, but I dont know LOL.
