89 Shadow code name: Kitsune
i just recently bought a shadow off my g/f and she beat the crap out of it badly... i have pics if anyone wants to see how it looks after a lot of work done to it but i was wondering if anyone knew of anything to do to it outside of my ES conversion project and the Evo Spoiler i plan to buy. if anyone knows of anyone that manufactures body kits for the car let me know too please! thank you
yes i have seen those kits but for what im doing i may buy one b/c it just looks better then what i have on it now. now i have two questions, my brakes wont work and i keep refilling it and there is no leak just wont pump the fluid and also i have a grind from first to second gear i know it is my syncros what do you recommend i do for that?
I don't know how to fix your tranny since my sundance is auto and my charger a man. but I haven't had any problems other then throwing 2 diff pins.
As for brakes check the rear drums if you have them you may have leak inside there that you don't even notice.
that may very well be the problem you know how hard it is to replace the brake piston b/c actually i seem to remeber that was popped out and it wasnt sutpposed to be when we did the back passenger drum
It not so bad it about get the line out of the piston. Taking the drums off is easy if there no rib form in the drum A dead give away of leaking one is look at your rims and the seem of the drum and backing plate for wetness.
