K-Cars The generation of cars that will forever live in infamy. The glorious K-car.
1989 k car... help please
Old Jun 30, 2004 | 03:35 AM
bubbles_k's Avatar
bubbles_k
Default 1989 k car... help please
does any one know where i can get a high quality valve gasket cover not a gay 3 part one?? i have a 1989 dodge aries k car and i dont really know anything about it!!! i know a lot about cars for being a girl but not about this. thanks
Old Jun 30, 2004 | 03:54 PM
87Indy500's Avatar
87Indy500
Default RE: 1989 k car... help please
If its the stamped steel valve cover, you only have one option. That is to use the 3 peice gasket set, but only use the rubber ends. Don't use the cork gaskets that come with the kit. Use only "Mopar" RTV down the sides where the the bolts attach the valve cover to the head. I have tried other RTV's but the Mopar brand seems to be the best.
Hope this helps
Old Dec 16, 2004 | 09:24 PM
cladmonitor's Avatar
cladmonitor
Thats not true I have an 86 Aries K with the stambed steel coverThe gasket I got was from Felpro.
Its Part number is VS50205T. Its a 1 piece gasket, the front and rear are reinforced with steel. Autozone's site has it for 21.99 I got mine at Autozone in San Diego for 14.00.
When I installed it used some Permatex High Tack for all the corners and havent leaked a drop.
Good Luck
Old Dec 22, 2005 | 02:49 AM
mechanic07's Avatar
mechanic07
i know that advance auto sales a whole piece gasket for about $10. If you can't find one there, i would try doing a search on google by typing in what you need and checking the results, but your best bet is to try advance auto.
