Help me locate my '85 Dodge Aries LE 2.2 Voltage Regulator
My battery isn't getting any charge, and I just replaced my Alternator. I bought a new voltage regulator (EVR) from schucks for my '85 Dodge Aries LE Fuel Inj 2.2L .
But I can't find the Voltage Regulator! Does anyone know where it is?
The Chilton manal says, "2.6L engines have an integral regulator, and all '88-'95 alternators are regulated by the Powertrain Control Module (PCM), and that other 2.2L or 2.5L engines "may" in corporate a separate regulator on the inner fender or on the firewall."
AutoZone.com says that the EVR is, "Under hood, passenger side, front side of strut tower, mounted on fenderwell."
I can't find it for the life of me. I even tried to follow the jumper harness from the Alternator leads but it just leads to the driver side fenderwell near the Power Module.
Any suggestions?
Any suggestions?
should be in the power module on driver side. You can fix the problem by replaceing the power module are you can rewire the car for extrenal one.
Try this site for help.
http://minimopar.knizefamily.net/electrical.html
