K-Cars The generation of cars that will forever live in infamy. The glorious K-car.
Need help performance-wise
Old Nov 12, 2006 | 09:12 PM
Dodge600's Avatar
Dodge600
Default Need help performance-wise
Hey, I just purchased a dodge 600 4 door with the 2.2L 4 banger and I was wondering where/if I could get any performance parts for it thanks.
Old Nov 13, 2006 | 12:10 AM
speedyshelby's Avatar
speedyshelby
Default RE: Need help performance-wise
You can but the best bet is convert it to a factory turbo setup
Old Nov 13, 2006 | 01:39 AM
Dodge600's Avatar
Dodge600
Yeah sure, but the factory turbo also has alot of things wrong with it.
Old Nov 13, 2006 | 11:31 AM
speedyshelby
Like what? My charger could do a mid 13 sec pass and I still get 25 mpg with it. What wrong with it?
Are afraid of the head gasket problems everyone seem to have. I been running turbo motors for 5 years and only had one true gasket problem.
Also my sundance I got. Bought the car 50 bucks. Bought another one (89 shadow es turbo) from a Jyard for 150 and I been running it for almost a year.
Old Nov 13, 2006 | 10:04 PM
Dodge600's Avatar
Dodge600
I'm not sure but my sources say they arn't great, but i think my car is the turbo one, it sounds like it has a blow off valve not sure if thats what its called or not but how would i check if it turbo charged?
Old Nov 13, 2006 | 11:33 PM
89Daytona's Avatar
89Daytona
Follow your intake from the filter to the engine, if there is a turbo you'll see it on your way to the engine.
You don't have to use a stock turbo, but using all the stock equipment (manifolds and such) on on the engine with an aftermarket turbo of your choice can get you lots of power.
You can also use a DOHC head from a 2.0L NEON on the stock 2.2/2.5 block http://home.comcast.net/~ozspeed/CylinderHead.htm
Old Nov 14, 2006 | 12:34 AM
Dodge600's Avatar
Dodge600
I just went out and looked at the engine but I can't find the intake or the filter, the engine confuses me
Old Nov 14, 2006 | 12:36 AM
speedyshelby
If it stock and has got turbo usaully it will say this on the valve cover.
What year is the car?
Old Nov 14, 2006 | 12:41 AM
speedyshelby
Here some thing close to a stock carb engine. Does the engine look the picture?
Old Nov 14, 2006 | 12:42 AM
Dodge600's Avatar
Dodge600
Uhh 85 I belive heres a pic:
[img=http://img297.imageshack.us/img297/3636/picture002fo3.jpg]
