K-Cars The generation of cars that will forever live in infamy. The glorious K-car.
Dodge shadow engine swap
Old Jan 24, 2007 | 08:57 AM
shadowestwin's Avatar
shadowestwin
Default Dodge shadow engine swap
I own a 92 Dodge shadow ES with a 6g72 V6 SOHC and I would like to put its more powerful brother in it(6G72 DOHC Twin Turbo) from the Mitsubishi 3000Gt. Is this a fantasty or a possibility? If it is a possibility how much work would this involve? how much money and time? would i need a different tranny? thanx
Old Jan 24, 2007 | 11:41 PM
speedyshelby's Avatar
speedyshelby
Default RE: Dodge shadow engine swap
Should keep it a fantasty. To start the engine are casted different for the heads. Also the tran don't swap. The engine sits in the engine bay backwards for yours. The wiring to get work would require alot. Also there no room in the engine bay for the turbos to fit. I seen a spirit with this swap the guy had more money in it to make the engine work then it would to build a 3000gt or stealth. He never did get it to run right. But there is hope for the engine that currently have. The motor do share the same pistons. There a bunch of people on turbododge.com that turbo the stock 3.0.
