1979 black dodge trans van with v8 magnum swap
Old Aug 18, 2019 | 01:11 AM
Viperdave's Avatar
Viperdave
Originally Posted by Spencer Yancey
Does it have a battery system to run the a/c when the engine is off? Im thinking about buying a spit on a secluded lake for a weekend getaway and wondering if an air conditioning battery system can be set up for night time.
Im useing a quad yellow Top optima set up but not for the a/c
its impossible to run a functioning motorhome a/c system off of 12 volts it’s run on 120 volt and an inverter would drain all 4 batteries realy quick
you need at least 3k watt generator to run the A/c I use a portable 3500 watt ggenerator that fits right inside the rear door and I just pull it out , put it outside and start it up. The ac only takes a few minutes to make it realy frigging cold inside , even when it’s over 100 outside!
