help w/ oil catch can
Alright so ive noticed that everyone has a oil catch can, and it sounds like it would be a good way to keep the srt running good. Now this is where you guys come in......where can i get one???? and also does anyone have directions for the install?
thanks for help
thanks for help
Go to http://www.jscspeed.com/srt4/srt4_base.htmlThe service and parts are great. The installation is self explanatory and only takes 10 minutes tops.
AGP 03-05 Dodge SRT4 PVC Oil Accumulator
The SRT-4 being a high horsepower turbocharged car runs a significant amount of piston-to-wall clearance. The cylinder pressure from the forced air creates more heat in turbocharged applications, thus DCX designed a "loose" engine for added safety and longevity purposes. Unfortunately, a byproduct of an engine that allows a lot of blow-by is oil residue makes its way past the PCV system and ends up in the intake manifold, and many other places. [/align]Oil residue in the combustion chamber of an engine is bad news, and can lead to really bad news with respect to how your engine runs. We have been testing a real solution for a while now that will actually separate the oil from the air flowing between the PCV and intake manifold. It sounds easy enough, and many people have tried to adapt simple catch cans and industrial water valves to remove the oil from the air. These systems are not as effective as a full on accumulator.[/align]
AGP's three chamber SRT-4 oil separator gathers the airborn oil particles through the middle chamber. Oil is separated from the air through the filtering media and drains through a perferated aluminum plate on the bottom side of the middle chamber then accumulating in the bottom chamber. As this oil gets filtered through the middle chamber, clean air is then filtered again and exits through the top chamber. This three chamber system design provides the best protection against unwanted oil making its way to the combustion process.[/align]
The bottom of the AGP SRT4 Oil Accumulator has a threaded 1/4" NPT bung and a plug to allow the user an easy way to drain the oil.[/align]AGP's SRT-4 Oil Accumulator is completely constructed of aluminum and is highly polished to provide some extra 'bling' to your engine bay. This will fit the SRT-4 perfectly and comes with hose and hose clamps for an easy installation. [/align]
Shipping costs are calculated upon checkout.[/align]
FITMENT: All 2003-5 SRT-4s[/align]
Our Price:
Part #:
$109
AGP-SRT-OILACCP
Availability: Usually Ships Next Business Day
Our Price:
Part #:
$109
AGP-SRT-OILACCP
