Ordered My first Mods!
Old Apr 3, 2007 | 04:09 PM
Racevette77's Avatar
Racevette77
Default Ordered My first Mods!
Well with the lil flutter problem and 2psi less boos ive been getting i decided to upgrade some. My car is Still stock Minus an AGPooc which ive had on for a few months now.
Ordered:
1) MSD Coil Pack
2) MSD Plug Wires
3) AEM Red Short Ram Intake
So with those few lil mods ...... what kind Spark Plugs yall recommend to get the max performanceouta my new MSD shiz and SRT-4 ;o)
Ill Post a Pic once all is installed.
Old Apr 3, 2007 | 04:47 PM
PSI Chick's Avatar
PSI Chick
Default RE: Ordered My first Mods!
well first off i recommend you call up and cancel that coil pack. the stock is more than enough and much more reliable.
that said, you can go with a denso itl16 irridium orthe ngk coppers and be perfectly fine. depends on what you want to spend. check on sparkplugs.com for options.
Old Apr 3, 2007 | 07:57 PM
Racevette77
Thanks.
Well regarding the coil pack i ordered it so ill stick w/ it. + itll look good all red and stuff and match the wieres. I allways keep a stock part unless its totally trashed so ill still have my stock pack for back up just incase.
Long Long Time ago i bought an MSD 6A Ignition system for an Old Formula 350 Firebird TPI that i had. I never installed it (accident totaled it /cry/ )and it is Still in the box like brand new. U guys / gals think i should have or could have it put on my SRT-4?
Old Apr 3, 2007 | 11:23 PM
flamingpinhead's Avatar
flamingpinhead
Section Moderator
well, your srt is a 2.4 4cyl, the firebird was a 350 V8... somehow i doubt compatibility
Old Apr 4, 2007 | 01:41 PM
PSI Chick's Avatar
PSI Chick
it won't work
