Haghn Racecraft
Old Apr 4, 2007 | 08:20 PM
orangesrt's Avatar
orangesrt
Default Haghn Racecraft
Does any one have any experience with their products. If not has any one ever heard anything about them. I'm thinking about getting their whole setup for the 20g kit.
Old Apr 4, 2007 | 09:24 PM
Plan B's Avatar
Plan B
Default RE: Haghn Racecraft
I'd check the 'other' forum, I believe they have a section dedicated to the 20g...
Old Apr 5, 2007 | 01:01 AM
silverblacksrt4's Avatar
silverblacksrt4
i'd like info on hahn turbo as well???
Old Apr 5, 2007 | 01:42 PM
PSI Chick's Avatar
PSI Chick
it's a nice set up as long as you're not looking to make over 400hp or so. it maxes out pretty quick.....
Old Apr 6, 2007 | 02:21 AM
silverblacksrt4
ehhh **** that then.. i want to get higher than 400hp
Old Apr 11, 2007 | 03:44 AM
srtratblock's Avatar
srtratblock
I havethe 20g on my ride with port fueler so far every thing woking fine.only have about 5k onit. Don't have any idea what kind of power that it's putting out until I get dynoed. This turbo beats the hell out of the old stock turbo. What I like about it is how it pulls in the 5k rpm to around 6k. gottheaem wideband, aem tru-boost controller, still have stock fuel pump. too change the subject a little I set spring pressure up to keep waste gate from opening up to soon, spools up fullaround 2700rpm, had boost hitting 22psi on 91oct. Never did run lean, stayed around 10.5 to11 on fuel. Unfortunetly it screwed my greddy b.o.v. up. "tired"
