upper control arm bushings
I was told in an earlier post that the upper control arm bushings would definately help with the wheel spin. On rage-tek.com So I went to check them out and all I could find were the lower control arm bushings I was wondering if this was the same thing. And I was wanting to know what would be a good clutch to handle the Stage3 the stock clutch has started to slip I am pretty sure that it is the pressure plate. Any help would be appreciated. Except from Valo or Kylem lololololololol
yea you're looking for lower control arm bushings. good mod.
as for the clutch, there are many options out there. clutchmaster s4, the upgraded mopar, comp race clutch, dcr just relased a new clutch that's pretty nice too. just stay away from spec and you're good.
