wga and boost hold help!
Hi there everyone!! i am sure there is somone that asked about this by now but i dont know, so i need to ask! ok i have a wga from agp and i was wondering on the stock fuel system what is the most i should peak at and what is the most i should hold to redline? Also when i get bigger injectors,fuel pump,wideband and a s-afc what can the stock turbo put out boost wise? i just dont want to blow my motor and i need help cause i do what more power but i dont know yet that much! right now i have a fmic,turboback and my wga set to peak at 19psi and holds 13 to redline! thanx everyone xoxoxoxo emily!
well....with the agp wga you should spike18-20 and hold 14-16.You have a fmic so thats a +!!Now with a fuel sys and piggy-bak you shouldnt go past19 or 20psi....go past that and you'll be hurting your motor, not to mention you wont be putting out any power, small turbo you know!!
Before you go out and get the safc check out the turbo xs dtec fc...a lot better than safc
thank you so much hun. i think i am starting to learn! i have one more question for now lol.ok how much will and can the stock turbo put out hp wise ? thanx for all help xoxoxo sorry one more thing! when you say i should not go past 19-20psi, is that on the upgraded fuel system or just the stock turbo in general?
ok what do you think i should do to get to 300whp? right now like i said all i have is a fmic,intake,turboback and this wga thing! what fuel mods do i need to run 300whp safe? is everything i named everythign i need? and what is this other thing you were telling me i should go out and get? how much is it about?
Return line, big injectors,fuel pump,fuel rail, and at least a piggybak.You shouldnt go past 20 psi on stock fuel sys or upgraded fuel sys.You wont hold 20 psi with stock fuel sys, you'll just spike and then drop.With upgraded fuel sys you'll hold those 20 pounds, if you go past that you'll be hurting your motor and turbo
