idle sensor
Old Apr 20, 2007 | 02:36 PM
PSI Chick's Avatar
PSI Chick
Default RE: idle sensor
you can either go to your dealership or call up jimmy at s&p and ask for the tps wiring fix. it's a new harness and will fix the problem. the issue isn't the sensor itself, it's the wiring harness. i think it's like $30 for the harness and takes like 20 minutes to change, it's pretty simple. once you get the harness it's easy to see where everything goes. you can replace the sensor too if you'd like, it's $35 i think and takes 4 seconds to change lol.
Old Apr 20, 2007 | 07:21 PM
silverblacksrt4's Avatar
silverblacksrt4
yeah i'm good friends with JIMMY at S&P.. where is this stuff located at?? MEANING: sensor and wiring???
Old Apr 20, 2007 | 08:06 PM
flameredsrt's Avatar
flameredsrt
On/in the throttle body
Old Apr 20, 2007 | 08:08 PM
silverblacksrt4
alrighty thanks guys/gals
Old Apr 20, 2007 | 09:48 PM
moparman04's Avatar
moparman04
mine does the same thing sometimes... fixed the tps but nothing.. any ideas?
Old Apr 20, 2007 | 10:41 PM
dustyloins's Avatar
dustyloins
Hall of Fame Member
Throwing any codes??
Dusty
