o2 sensor
Old Apr 19, 2007 | 09:15 PM
eng37ine's Avatar
eng37ine
Default o2 sensor
Hey guys, whats up? I've notice that my gas mileage has gone down alittle. I just had new tires put on, balanced and all that, i was wondering how long before we need to replace the o2 sensors. i know if that they become fouled, they become lazy and use fuel than needed. Any info will be appreciated. John
Old Apr 19, 2007 | 11:07 PM
PSI Chick's Avatar
PSI Chick
Default RE: o2 sensor
unless you have like 100k miles or are running leaded gas on a regular basis they should be fine. if they go bad they throw a code too. check your tire pressure and your driving habits. lay off the boost some lol
Old Apr 19, 2007 | 11:19 PM
dustyloins's Avatar
dustyloins
Hall of Fame Member
I agree, they install those things to last a loooooooooong time. Trying to replace or remove one is a pain.
Dusty
Old Apr 20, 2007 | 01:41 AM
silverblacksrt4's Avatar
silverblacksrt4
yeah i agree.. i think that u are probably boosting high.. got a boost controller?? set ur boost real low when u are just driving to work, etc.. but when u racing or whatever crank it up..
Old Apr 20, 2007 | 02:58 AM
flamingpinhead's Avatar
flamingpinhead
Section Moderator
along with checking pressure and yourself, when was the last time you checked your plugs as well? this car is known to eat them.
Old Apr 21, 2007 | 05:20 PM
eng37ine's Avatar
eng37ine
thanks for all of the advice. Think the problem might be my right foot. lol
