turbo xs RFL
Old Apr 23, 2007 | 11:59 AM
SRTUNIT2's Avatar
SRTUNIT2
Default turbo xs RFL
i got this installed yesterday but sounds like mopar bov then the rfl fires (user to have mopar bov but installed block off plate)anyone else have same problem and how was it fixed---also i wasnt sure where or how to connect the other end of the vacumm on the top of the rfl? any help would be great.
Old Apr 23, 2007 | 12:22 PM
redevil's Avatar
redevil
Default RE: turbo xs RFL
I got RFL.How many wahsers did you put on the spring?Have you cheked for boost leaks?The vac hose from top of bov goes to the hose by the throttle body.Wellmine is freakin' loud, never had any problems with it and it holds boost pretty damn good.Check the clamps for boost leaks and get back at me
Old Apr 23, 2007 | 07:31 PM
SRTUNIT2's Avatar
SRTUNIT2
i went to the install thread for aftermarket bov and its says to disconnet pink ling ging to the stock surge valve--what am i to do with it then its attached to a bunch of sensors?
Old Apr 23, 2007 | 10:15 PM
valoagain!!!!'s Avatar
valoagain!!!!
poop
Old Apr 24, 2007 | 12:15 AM
PSI Chick's Avatar
PSI Chick
ORIGINAL: SRTUNIT2
rip it out. it's not attached to any sensors, it's attached to the solinoid packs. you don't need it. you don't need most of the vacuum lines in there in reality. i think i have two left in my car lol
Old Apr 24, 2007 | 12:53 AM
SRTUNIT2's Avatar
SRTUNIT2
can anyone tell me what the stock surge valve looks like? describe or has a pic? thanks again.
