occ vs oil accumulator
Old Apr 30, 2007 | 04:44 PM
MAssSrTdriven's Avatar
MAssSrTdriven
Default occ vs oil accumulator
whats better between an oil catch can or an oil accumulator>? or are they basically the same thing? or should i just get one of each :P
Old Apr 30, 2007 | 05:02 PM
PSI Chick's Avatar
PSI Chick
Default RE: occ vs oil accumulator
wtf is an oil accumulator?
Old Apr 30, 2007 | 05:05 PM
redevil's Avatar
redevil
lmao.....i'm guessing its the same as a cc....dude just buy or make a cc!
Old Apr 30, 2007 | 05:53 PM
dustyloins's Avatar
dustyloins
Hall of Fame Member
They are two totally different animals The OCC catches oil that gets blown by the PCV valve and prevents it from gunking up other parts of the engine. An accumulator is used inmostlycompetition engines and prevents starting line and finish line oil starvation by injecting extra oil into the system when required........
Dusty
Old Apr 30, 2007 | 06:39 PM
flamingpinhead's Avatar
flamingpinhead
Section Moderator
just get an OCC
Old Apr 30, 2007 | 08:37 PM
motorboy1's Avatar
motorboy1
Yep dustys the man! I had an oil accumulator on my 7 sec dragster. It actually held an extra 3 quarts of oil in it. do to the negative Gs of the parachute the oil in the pan goes to the front of the motor were the oil pick up cant reach it, starving the motor of oil. oil presure would go to 0 sometimes, not good! with the accumulator it feeds those 3 to 5extra quarts when needed. kept me at 20psi while slowing down but still not good enough for my nurves. Dry sump best way to go 100 psi through the traps only droping to 60!
However not what you need! OCC all the way.
Old May 1, 2007 | 10:23 AM
MAssSrTdriven
thanks dusty, i seen a site selling both but i figured they were the same thing, but i guess not and i will not buy one now thanks!
