jet pcm
Old May 1, 2007 | 10:36 AM
joshgish's Avatar
joshgish
Default jet pcm
Has anyone ever had a jet pcm or know anyone with one? They make a stage 2 for our car and it is $240 about the same as stage 1 mopar used and I was thinking about getting the jet one just wanted some feedback on it first.
Old May 1, 2007 | 09:33 PM
dustyloins's Avatar
dustyloins
Hall of Fame Member
Default RE: jet pcm
The MoparStage 2 for the SRT-4 is more than just a PCM, you need to check and see what you're getting for your money......
Dusty
Old May 2, 2007 | 05:32 AM
joshgish's Avatar
joshgish
Default RE: jet pcm
I know the mopar stage 2 is more but I am comparing it to the mopar stage 1 where I just get the new pcm since I have an 04. The jet says it adjusts timming and fuel and a couple other things but supposedly can give you up to 25 hp if you have a 180 degree thermostat and exhaust. I just wanted to know if anyone has it or know someone with one.
Old May 2, 2007 | 07:46 AM
flamingpinhead's Avatar
flamingpinhead
Section Moderator
Default RE: jet pcm
if it were me i would stick with mopar and wait to pick up aMopar S2. or just pickup the Mopar S1
