any anwsers
Old May 4, 2007 | 08:24 PM
03srt4's Avatar
03srt4
Default any anwsers
got a little bit of shaking from sterring wheel at 80 to 90 mph. took to shop and they said nothing is wrong anyone got any anwsers
Old May 5, 2007 | 12:10 AM
flamingpinhead's Avatar
flamingpinhead
Section Moderator
Default RE: any anwsers
80-90, kinda quick eh?
anyhow, how old are your tires? worn edges will cause vibration at higher speeds. also to blame could be tire balance. good place to start with vibrations is looking at your tires. then move on up the components from there.
edit:
and its likely not the case, as it would probalby be more noticable across the board, but might want to check and make sure no one loosened your lugs.
Old May 5, 2007 | 01:16 AM
dustyloins's Avatar
dustyloins
Hall of Fame Member
You might want to check for mud on the inside of the rims if you've done any driving inmessy conditions......
Dusty
Old May 5, 2007 | 02:25 AM
03srt4's Avatar
03srt4
thanks for the tips
