just my luck check engine light
Old May 6, 2007 | 08:34 AM
srt4sparks's Avatar
srt4sparks
Default just my luck check engine light
Someone help i got a check engine light how do i reset this thing. The car is stock its a 2004 srt4 no mods whatsoever. I started my car up this morning to let it warm up and my girl told me yo babe the check engine light came on i told her you didnt touch anything did you she said no i went okay and now im back here asking you guys questions. How do i just reset the check engine light codes whats the procedure step by step.
Old May 6, 2007 | 08:44 AM
flamingpinhead's Avatar
flamingpinhead
Section Moderator
Default RE: just my luck check engine light
the sticky up top has all the codes and what they mean:
to actaully get the codes:
Ok, here's what you do:
1. Put the key in the ignition.
2. Turn key all the way forward - not to the point where the car starts, just to the point where all the lights come on. Do it in this sequence: ON-OFF-ON-OFF-ON..
3. Keep a close eye on your odometer. You will see a series of codes display, followed by the word "donE"...
4. These codes will tell you why the "Check Engine Light" is coming on.
5. If you see "P0442" followed by "P0456". These codes mean respectively: EVAP sensor detection... SMALL LEAK. IF IT IS THESE SET OF CODES, fear not - nothing is wrong with your car. Simply tighten your gas cap, then...
6. Pop the hood, disconnect the NEGATIVE battery terminal - DO NOT DISCONNECT THE POSITIVE TERMINAL - FOR THE LOVE OF GOD. You will run the risk of shorting out the electrical system.
7. Wait a couple of minutes, then reconnect.
8. Start the car up and TADA! CEL is gone!
reference: ttp://www.dodgeforum.com/m_409789/tm.htm(very long list of codes here as well)
Old May 6, 2007 | 08:52 AM
srt4sparks's Avatar
srt4sparks
thankyou very much broman i never knew my car could be so touchy i just wanna make sure my baby is good so that i can throw the stage 2 up in there and get busy. because stage 3 is a little extreme for me i doubt if ill get any traction with it its just for the street .
Old May 6, 2007 | 09:20 AM
redevil's Avatar
redevil
DRs!!!!!
