oil sending unit?
Old May 6, 2007 | 11:06 PM
blue_srt4's Avatar
blue_srt4
Default oil sending unit?
i think there is a problem with my oil sending unit. everytime i start my car the oil light comes on, but then i turn the car off and turn it right back on the light goes out. is my oil sending unit bad? or what do u guyz think is the problem?
Old May 7, 2007 | 04:35 AM
71RoadRunner's Avatar
71RoadRunner
Default RE: oil sending unit?
Start with doing the computers self check. If nothing shows up you might want to take it in for service, oil pressure is nothing to ignore and that is why I prefer gauges over idiot lights. If the car runs fine it could simply be a bad connection or wire.
Old May 7, 2007 | 11:28 PM
blue_srt4's Avatar
blue_srt4
could u refresh me on the computer self check? i always forget this.
Old May 8, 2007 | 06:56 PM
Plan B's Avatar
Plan B
Turn the key three times w/o actually starting the car....
What oil are you running? When I was running Amsoil I had the same thing happen. The light would come on and go off. Once I put Mobil back in it I never saw the light again. I agree w/ 71RR, get a oil pressure gauge. Even if it is just to ease the mind, it worked for me!
Old May 9, 2007 | 01:28 AM
blue_srt4's Avatar
blue_srt4
well one problem is the OSU's location. it seems very hard to get to, almost like u gotta pull the motor to get to it. im using royal purple, and have been for a while. wouldn't u hook a gauge up to where the osu is? after thinking about it, i believe it will be fine as long as the light goes off when i turn the car back on. now if im driving down the road and the light comes on, i think then yea i have a problem. mainly right now its just annoying.
Old May 9, 2007 | 02:41 AM
Plan B's Avatar
Plan B
I hooked the gauge up to where the dummy light sensor for the PCM goes. Just 'T'd" them both in there. You can get to it with a lift, and it helps to take out the downpipe (did mine when I did the o2 housing and exhaust). Just gives you some room.....
Old May 9, 2007 | 05:25 AM
joe440's Avatar
joe440
My car does the very same thing.Just started the day I had the Stage2 intalled.I have a oil pressure gauge and everything is good. I just don't like having the oil light on all the time.
