stock turbo boost
Old May 21, 2007 | 10:00 PM
tyler819's Avatar
tyler819
Default RE: stock turbo boost
i think it spikes 17-18 and then goes back and holds 15
Old May 22, 2007 | 03:17 AM
PSI Chick's Avatar
PSI Chick
ORIGINAL: tyler819
is just getting bigger injectors enough to run 17-18psi?
no because without a return line and fuel controller you'll have some serious problems
Old May 22, 2007 | 06:33 PM
Plan B's Avatar
Plan B
ORIGINAL: tyler819
I don't see a reason why you would need any fuel mods then. I spike the same and hold around 16 and I am still running really rich with 04/s1 injectors and a stock fuel setup....
Old May 22, 2007 | 10:33 PM
tyler819's Avatar
tyler819
oh ok thanks for the info., i have a wideband gauge alredy in the A pillar that tells me if i am running rich or lean but i have to get some 2 sensor from some '90 somethin dodge stealth or some other dodge car to make it work i was told because the o2 sensor in the srt-4 is not compatible with it.If anyoneknows how to make this work i would greatly appreciate some help thanks. Then i will be able to know if she is running lean or rich.
Old May 22, 2007 | 10:56 PM
Plan B's Avatar
Plan B
ORIGINAL: tyler819
You will need an aftermarket widebandO2 sensor. I believe Bosch? I don't think a 90' somethin Dodge stealth will have the right sensor, probably a narrowband.....Which wideband gauge do you have?
Old May 23, 2007 | 10:21 PM
tyler819's Avatar
tyler819
it is a autometer wideband gauge, i just was told that i have to go to autozone and buy a certain kind of o2 sensor to make it work because the stock one isnt compatible
Old Oct 6, 2007 | 09:47 PM
jromig's Avatar
jromig
Hey in fifth gear has yours hit 18-20 spiked. Just wondering if that is normal or not. Thanks 2005 srt4
Old Oct 10, 2007 | 05:08 PM
srt4ACRboy's Avatar
srt4ACRboy
ORIGINAL: jromig
i think that it is, do u punch it when you are at a low rpm if so that is normal, mine does that to, spikes to 17-18 and falls down quickly to 15.
Old Feb 6, 2008 | 11:23 PM
mldsrt4's Avatar
mldsrt4
when i bought my car i thought it was stock....but i hear that stock they hold about 12....and my car holds 17....is this stage 1 do you think...?
