walbro fuel pump
Old May 20, 2007 | 06:09 PM
silverblacksrt4's Avatar
silverblacksrt4
Default walbro fuel pump
is a walbro fuel pump a needed upgrade if u have bigger injectors and running higher boost??
Old May 20, 2007 | 06:41 PM
srt4sparks's Avatar
srt4sparks
Default RE: walbro fuel pump
It depends on for one how much power are you planning to push. In most cases you need to change both the fuelpump to aftermarket aswell as the injectors aswell as the fuel rail which i didnt have to do with my old car and fuel pressure regulator.im not sure with these cars about changine the fuel rail and regulator but on my honda i had to. The more air you plan on putting into the combustion chamber you gotta have enough fuel to help that air create more power. if not youll run lean and overtime *boom* exactly how much power are you exactly looking to get to the wheels?
Old May 20, 2007 | 09:13 PM
PSI Chick's Avatar
PSI Chick
99% of the time, yes.
