Greddy OCC Question
Old May 29, 2007 | 02:50 PM
srt4ACRboy's Avatar
srt4ACRboy
Default Greddy OCC Question
I just got my aem short ram and my oval greddy catch can and i have no idea how to put the catch can on. Intake<<CC<<PCV? anyone have a picture of theres on that they could show me?
(I dont know where the cc or the pcv is either) = newb
Old May 29, 2007 | 04:21 PM
redevil's Avatar
redevil
Default RE: Greddy OCC Question
ok i'll give ya a hand.Your cc has two inlets right?well run a hose from one of the inlets to you pvc valve, wich is located on the left hand side of you valve cover, there should be a line allready hooked to the pvc valve, if you want disconect that line and run a new fuel line from there to the inlet in your occ.Then run another line from the other inlet to the throttle body.Where in the tb? well remember that first line you unhooked from the pvc valve, the other end hooks up where your 2nd line should be hooked at.Hope I didnt make it too complicated, I tried to give lots of details because it can get confusing.Remember to use fuel lines wich are a lot more resistant to head than the ones that come with the occ.Hope this helps
Old May 29, 2007 | 06:04 PM
Plan B's Avatar
Plan B
Good explanation Red...
Also, if you have the Greddy OCC with the little view tube, keep an eye on it. That little view tube had a considerable leak on my buddie's.....
Old May 29, 2007 | 06:54 PM
srt4ACRboy's Avatar
srt4ACRboy
how much should i get of fuel line, and what size lines?
Old May 29, 2007 | 09:22 PM
Plan B's Avatar
Plan B
I forget what size, but 3ft should be more than enough. I recently replaced my fuel line with some braided air compressor hose line, the fuel line was colapsing on me....
Old May 29, 2007 | 09:50 PM
Dave_04's Avatar
Dave_04
Air hose line is the best and will not collapse.
<a href="http://photobucket.com" target="_blank"><img src="http://i62.photobucket.com/albums/h8...0/CatchCan.jpg" border="0" alt="Photo Sharing and Video Hosting at Photobucket"></a>
Old May 30, 2007 | 06:25 AM
flamingpinhead's Avatar
flamingpinhead
Section Moderator
fuel line works as well. im pretty sure i used 1/4"
i cant access my photobucket at work, but i have a decent illustration on there very fitting to redevil's description. and he is very right about the lines that come with the can... they are crap. they get heated up way too easily and practically melt. they also expand under boost and suck shut under vacuum (especially when hot). mine isnt a Greddy, but its the exact same thing with a different name on it.
my post from https://dodgeforum.com/m_642068/tm.htm: i cant see them but the pictures should show up
ORIGINAL: flamingpinhead
yeah, its a quick moneypit once you start modding... and its addicting. you can mount the occ over on the passanger side of the engine, or if you have aCAI you can easily mount it around the battery tray.
the one from the PVC to the Intake manifold (yellow) is really the only one to be concerned with. the other one is easily bypassed by placing a breather on the crankcase vent. it just looks pretty. i took the 2nd one off a couple weeks ago when i converted to short ram intake for the winter.
btw, i know my images says 'throttle body', but its really the intake mainfold it actually plugs into.
and lastly, a rough sketch of how the occ works:
the pvc the valve on the top passanger side. if you follow that factory line in yellow, it comes to the pvc where the hose connects. the pvc is, correct me if im wrong, a check valve. problem is when the turbo is spooling and it pressurizes the system, this line from the pvc to the manifold is under pressure as well. so oil and gook blows through it, into the TB, intake manifold and intercooler get crap flowing into them
Old May 30, 2007 | 01:38 PM
redevil's Avatar
redevil
damn flaming...you went all out on this one...lololol...good job
Old May 30, 2007 | 01:49 PM
Burnnout's Avatar
Burnnout
Flaming ...... your catch can in the last pic. must have hole in the bottom. [8D]
Old May 30, 2007 | 01:55 PM
srt4ACRboy's Avatar
srt4ACRboy
ya tell me about it, but i appriate the time and pictures thanks everyone!!!!
