a bad miss under throttle
Old Jun 4, 2007 | 03:31 AM
joshsucs's Avatar
joshsucs
Default a bad miss under throttle
I have a 2004 SRT-4 with a bad miss when I push the throttle, acts like a rev limiter. Runs fine when ease into the throttle. I bought the car used it has aoil catch canthis is all I see that has been changed
please help
Old Jun 4, 2007 | 12:54 PM
SRT_YA's Avatar
SRT_YA
Default RE: a bad miss under throttle
plugs? wires? TPS sensor?
Old Jun 4, 2007 | 01:58 PM
blackacr's Avatar
blackacr
mine did that about a month ago (@ 21k miles, checked plugs and they where way too wide, regaped to .35 and works fine now. I've heard that this is a common issue.
Old Jun 5, 2007 | 12:29 AM
waylon's Avatar
waylon
Member
Change your plugs and wires and that should do it. My '03 did the same thing at around 23k and again around 28k and finally the last time very recently at around 80k miles. Mine never threw a code but there is a tsb about exactly the symptoms you described. Should be able to get 40-50k per set of wires/plugs after the dealer changes them.
Old Jun 5, 2007 | 03:08 PM
flameredsrt's Avatar
flameredsrt
ORIGINAL: waylon
Man i wish.I am changing my NGK 4306's every 5-7k
