whats the best BOV
Old Jul 1, 2008 | 05:47 PM
srt421's Avatar
srt421
Default RE: whats the best BOV
which bov is better thehks ssqv or the synapse syncro? also i have the stock turbo? but probably getting the mopar s3 kit which works/sounds better?
Old Sep 8, 2022 | 01:55 AM
Martin Lisa's Avatar
Martin Lisa
Question What Is the best Sounding Blow off valve ?
There is no definitive answer to this question as it is subjective. Some people may prefer the sound of a particular blow off valve because it is louder or has a more aggressive tone. Others may prefer a blow off valve that is quieter or has a more subtle sound than a typical turbo. You can also select from different styles, sizes and materials. In the end, it is all about your personal preferences and the look you desire for your vehicle. What Is The Best Way To Install A Blow Off Valve On Your Turbocharged Car? You can install blow off valves in many ways. Many people will install them where the stock valve was located. Others may install them on the hose that leads from the turbocharger to the intercooler or throttle body. It is important to mount your blow off valve in a stable location so that it does not loosen over time and cause leaks. Once you have selected a mounting location, you will then need to secure it with bolts or clamps so that it stays in place. There are no set rules when installing blow off valves, although most people prefer to keep them simple and clean looking by mounting them where they are out of sight and do not interfere with other components in the engine bay. Ultimately, it is up to the individual to decide what sounds best to them.
