wastegate pressure line
BLK ... if the line to your wastegate is unplugged you would be boosting like 20+ psi .... all of your lines need to be routed the way they came from the factory.
Tyler819 what mods do you have ?
im sure that all my vac lines are hooked up as stock but i heard if you change them around a ceratin wayu can get more hp depending on mods. I have allstage 2 minus the ecu and w/o toys, 3' downpipe cat delete, 2.5' borla exhaust,huge fmic,solid motor mounts, and spiking like 18-20 lbs and holding like 15-17lbs all depends wat gear im in.
i have fixed my waste gate prob. actually it was only spiking 15 holding at 10. but all my lines are ran correctly now. and the wiring diagram is on the hood of your car. just follow everything
