boost controller
Old Jun 15, 2007 | 09:48 PM
deepseastetson's Avatar
deepseastetson
Default boost controller
i got my turbo xs standard boost controller in the mail. it came with no installation instructions. i know the way it works is a line from the wastegate actuator. and a line from the pressure source(turbo). i see a line coming off the wastgate actuator but all it does is circle around behind the turbo and connect to a sylinoid or something. i have never worked on turbocharged cars and i just need a little advice on how to install it
thanx
Old Jun 23, 2007 | 11:49 AM
Burnnout's Avatar
Burnnout
Default RE: boost controller
If you are on the stock turbo / stock vaccuum line set up, then all you do is run it in line with the black line going to the wastegate....... hope you have some other mods.
