Problem with my idoling...help
Old Oct 5, 2004 | 08:32 PM
Bucs80's Avatar
Bucs80
Default RE: Problem with my idoling...help
they are keeping it over night, but the good thing is that the mechanic heard the RPM's going crazy when i pulled up. he said he should be able to fix it by tomorrow morning. ill let ya'll know what was wrong with it.
Old Oct 6, 2004 | 10:58 AM
glhs837's Avatar
glhs837
trax, does he have a catchcan also? That can cause similar symptoms if the lines are loose.
Old Oct 6, 2004 | 11:04 AM
dustyloins's Avatar
dustyloins
Hall of Fame Member
Good to know. Another reason to check those hose clamps from time to time....
Old Oct 6, 2004 | 01:18 PM
TRAXMAN199's Avatar
TRAXMAN199
ORIGINAL: glhs837
Nop, no catch can or vacc leaks, so he said. IM going to try to help him figure it out prob this weekend. Will see
Old Oct 6, 2004 | 02:58 PM
Bucs80's Avatar
Bucs80
Picked up the car today, they replaced the Throttle Position sensor. crossing my fingers that it worked, so far so good.
Old Oct 6, 2004 | 03:12 PM
dustyloins's Avatar
dustyloins
Hall of Fame Member
glhs and Barneydriver called it right!!!
Old Oct 7, 2004 | 06:23 AM
Barneydriver's Avatar
Barneydriver
ORIGINAL: dustyloins
Barney, they told me I'd have to make an appointment, blah, blah, blah, for that #4 wire.
How about you?
yeah, he just told me to come in the next day, though, since they had some openings- i actually had to cancel, b/c i had too much to do to get ready for the deployment (leaving tomorrow- hopefully i'll talk to you in a couple days if i can get some computer time!).
Old Oct 7, 2004 | 06:31 AM
71RoadRunner's Avatar
71RoadRunner
Odd how the TPS would cause spikes like that only while in neutral and not while in gear. I figured if it were the TPS it would do it off and on all the time, in gear as well as in neutral.[&:]
Old Oct 7, 2004 | 09:34 AM
Bucs80's Avatar
Bucs80
well while in gear, it would act as a cruise control. doesnt do that anymore, i still gotta drive it hard, i love driving on these german roads, it makes driving fun.
