Do I Have A Boost Leak?
Old Jul 17, 2007 | 10:15 PM
srt4ACRboy's Avatar
srt4ACRboy
Default Do I Have A Boost Leak?
Recently I have been noticing that when I start up my car from sitting for a while, when I punch it I am getting a boost reading of about 10! Then when it gets warmed up i get a reading of about 15 and it says like that the rest of the ride. Then tonight I was coming home from work, i started it up and i was getting a reading of 18-19 when i punched it! Then the engine would warm up again and i would punch it and get a normal reading of about 15. What the hell is going on?
Old Jul 18, 2007 | 01:19 AM
PSI Chick's Avatar
PSI Chick
Default RE: Do I Have A Boost Leak?
car changes boost levels until it's warmed up, trying to save the engine and turbo from excessive wear.
if you think you might have a boost leak just do a leak test and see. check your lines while you're in there.
Old Jul 18, 2007 | 11:31 AM
srt4ACRboy's Avatar
srt4ACRboy
alright sounds good, it really scared me when i seen it jump to 18-19 psi, that is good to know though thanks
