can i slowly upgrade to stage 2!!??
Old Jul 20, 2007 | 12:50 AM
SMTYLEZ's Avatar
SMTYLEZ
Default can i slowly upgrade to stage 2!!??
ummm, ok lets say i want to upgrade to stage 2 from stage 1, can i first buy the ecu used, an get it flashed, the the injectors, and the sensors..? or do i have to get it all at once, or have to buy it all together brand new?? is any stage 2 ecu used going to work on my car if i buy it.. w/o toys??? any help asap thank alot
Old Jul 20, 2007 | 01:13 AM
PSI Chick's Avatar
PSI Chick
Default RE: can i slowly upgrade to stage 2!!??
sure you can collect the parts over time, just install it as a kit. the car won't run properly if all the components aren't there.
03/04 ecus are interchangable. 05's are different. i'm not sure what year yours is, can't remember off hand.
Old Jul 20, 2007 | 12:57 PM
SMTYLEZ's Avatar
SMTYLEZ
where can i get the ecu flashed or reflashed, or does it have to be sent out to be flashed?
Old Jul 20, 2007 | 02:16 PM
PSI Chick's Avatar
PSI Chick
any dodge dealer can do it, but most either won't or want to charge you $150. send it to flightsystems.
