LC-1 and DTEC FC Datalog Help...
Old Jul 22, 2007 | 12:38 PM
Aceburner's Avatar
Aceburner
Default LC-1 and DTEC FC Datalog Help...
Ok so I'm about to use my DTEC FC with the LC-1 Analog Port so I can datalog the A/F Ratio's with the rpms and so forth. Me and my friend where looking forever for the spec on making them talk to each other. Please if anyones knows how to do this any info will help. I know I have to set the right calibrations so they can talk to ach other the right way. Any help would be greatly appreciated.
PSI... I know u may know of this... or at least maybe where I can find it.
Old Jul 22, 2007 | 05:46 PM
PSI Chick's Avatar
PSI Chick
Default RE: LC-1 and DTEC FC Datalog Help...
http://www.srtforums.com/forums/show...=dtec+innovate
see if that helps
Old Jul 23, 2007 | 05:25 AM
Aceburner's Avatar
Aceburner
Ah yes... thank you... it says LM-1 but it should work for the LC-1 too I guess.
Old Jul 23, 2007 | 09:06 AM
PSI Chick's Avatar
PSI Chick
yea it should be pretty much the same.
