alum flywheel vs oem
Old Jul 27, 2007 | 05:35 PM
turbosrt's Avatar
turbosrt
Default alum flywheel vs oem
Is there a big advantage in having the aluminum flywheel vs steel? i have a 60 trim pushing around 480hp, so i thought this should help with turbo lag. i just ordered clutchmaster stage 4 6 puck with alum flywheel and i hope i made a good choice.I was going with PTP clutch for 550 shipped with reg flywheel but decided go with cm s4 alum fw instead, anyone that has this same clutch care to chime in? is there a fix for the noisy tob that i had in my previous clutch? i dunno which brand or stage it was it came with the car when i bought it few months ago....any help would be appreciate it
Old Jul 27, 2007 | 06:46 PM
tyler819's Avatar
tyler819
Default RE: alum flywheel vs oem
i just put a clutchmasters stage3 in with the alum flywheel and i notice a big differance in throttle response and im sure it could make a big turbo spool faster but i have the stock turbo so i can only notice a little difference in spool time with the alum flywheel, i love the alum flywheel so far...
Old Jul 29, 2007 | 11:20 AM
PSI Chick's Avatar
PSI Chick
an aluminum flywheel isn't going to make a major difference no matter how much power you're putting down. sure it helps, but it's not going to change spool time by like 1000 rpms or anything like that
