PLEASE HELP!!!!!
Old Aug 4, 2007 | 12:26 AM
HODGEDODGE's Avatar
HODGEDODGE
Default PLEASE HELP!!!!!
Someone please help???just bought my04 srt-4 about 2 months ago and love it.but now im getting an engine code. i dont remember the number off hand but the description said 'throttle inlet pressure sensor circuit problem'.. it runs really good untill the turbo spools to 12psi and above then it seems to have a really bad misfire. if i let up on the throttle and let the boost go down it goes away. i replaced the throttle inlet pressure sensor (26$) and that didnt fix it. i kinda feel stupid cause im actually supost to be a mechanic but dont work on turbo cars at all. any help would reallybe greatfull thanks alot.!!!
Old Aug 4, 2007 | 10:35 AM
PSI Chick's Avatar
PSI Chick
Default RE: PLEASE HELP!!!!!
heyi just got your email but i thought i would just respond here.
did you replace the sensor or the wiring harness? the problem isn't the sensor, it's the wires. you need to extend the ground to the sensor, it's too short and when the engine moves the wire snaps in the sheath.
Old Aug 4, 2007 | 03:21 PM
HODGEDODGE's Avatar
HODGEDODGE
hey thanks alot i will start tracing wires this evening thank you!
