bad idle, rough ride
i noticed the last couple weeks my car has been riding real rough, i went to start it up tonight to go to work...and the idle sounded terrible like it was almost misfiring, open the hood..first inspect my wires make sure those are tight. and what do ya know if looking at the engine the right front wire shocked me! none of the other wires did this when i was feeling them to make sure they all were tight, now this means i have ****ty wires (yes they are stock) so now that i know i have ****ty wires because it shocked me through the rubber boot and they all were tight, i need to know best way to go, i want to do coil pack, plugs, wires ASAP. my car can not be put thru this lack of igniting to the cylinder!!!! i will not allow it. so any suggestions on brands to go with and size of wires?
stock coils seem to work great. as for wires, i have the 10mm 1200 degree wires from sparkplugs.com and they're not too pricey. plugs i'm using are kind of expensive but they seem to work much better than the ngk 4306's i had - right now i'm using denso iridium plugs.
