quick coil pack help
Old Aug 18, 2007 | 08:40 PM
MAssSrTdriven's Avatar
MAssSrTdriven
Default quick coil pack help
im buying a new coil pack, modern performance says: to know what kind of plug connects to my coil pack is its round or flat. uh i beleive the site says 96-2003 has flat plug style if it wasnt dark out and i had a flashlight i would check myself, my srt is a 2005. so i would guess flat? anyone got a fast quick answer so i can order this asap, before tomorrow lol
Old Aug 18, 2007 | 09:31 PM
tyler819's Avatar
tyler819
Default RE: quick coil pack help
if u need a new coil pack u should buy an oem one, they are better than the msd coils. i tried the msd coilon my 05 srt4 and i got a misfire code. but if ur set on the msd it is the flat prongs.
Old Aug 18, 2007 | 09:37 PM
MAssSrTdriven
really....well honetly my coil is fine, but my wires do have a leak on number 3 wire. so those HAVE to get changed i figured id upgrade the plugs wires an pack together might as well but if thats true then idk
Old Aug 18, 2007 | 09:53 PM
tyler819's Avatar
tyler819
just stick with the stock coil ifits fine. just get some msd 8.5mm wires and u will be fine and save urself $70
Old Aug 19, 2007 | 01:24 PM
aiverson's Avatar
aiverson
ORIGINAL: tyler819
x2 for the stock coil, the msd is POS, I just thru one out. it started to cut out after 10 psi. replaced it with the stock.
