Stage 1 and stage 2 ecm's
Old Sep 1, 2007 | 08:40 PM
T_U_R_B_O's Avatar
T_U_R_B_O
Default Stage 1 and stage 2 ecm's
well im deff going to get a staged ecm.. but i only want the ecm its self.. is there a diffrencebetween the 2 ecm's or are they the same... if there is a didd can u guys let me knoo
help plz!!!
Old Sep 1, 2007 | 09:50 PM
dustyloins's Avatar
dustyloins
Hall of Fame Member
Default RE: Stage 1 and stage 2 ecm's
They are different. And the Stage 1 PCMwill come with larger injectors if you have a 2003 model.....
Dusty
Old Sep 2, 2007 | 10:35 PM
T_U_R_B_O's Avatar
T_U_R_B_O
Can anyone tell me what the diffences are between the s1 and s2 ecm's
Old Sep 2, 2007 | 11:05 PM
dustyloins's Avatar
dustyloins
Hall of Fame Member
The Stage 2 PCM delivers more power to the engine and works with the optional toys ......
Dusty
Old Sep 3, 2007 | 02:19 PM
aiverson's Avatar
aiverson
stage 2 comes with injectors 3 bar map and tip sensor and a new wga. Also you can get it with toys. you will not able to just swap the pcm like a stage 1.
tony
Old Sep 3, 2007 | 04:13 PM
T_U_R_B_O's Avatar
T_U_R_B_O
if u get a stage 1 ecm cant i justinstall bigger injectorssepretly..
Old Sep 3, 2007 | 10:40 PM
blue_srt4's Avatar
blue_srt4
yes. most ppl go with stage 1 if they're gonna run aftermarket turbo.
