Tuning wiTh stage 2
Old Sep 3, 2007 | 10:47 PM
T_U_R_B_O's Avatar
T_U_R_B_O
Default Tuning wiTh stage 2
i found a stage 2 ecm... i am thinking about getting it and the injectors seperate... it will be alot cheaper.. anyways i was wondering if tuning is easier with a s1 ecm or s2 ecm.... or does one ecm give you more power than the other...
thanks guys and girlssss
Old Sep 3, 2007 | 11:41 PM
PSI Chick's Avatar
PSI Chick
Default RE: Tuning wiTh stage 2
if it's just the ecu either one will be about the same.
Old Sep 3, 2007 | 11:42 PM
Kapitald's Avatar
Kapitald
stage 2 comes with a bigger set of injectors than stage 1....so yes it will offer more power because the injectors are larger....stage 2 also utilizes a 3 bar tip and map sensor....and a better wastegate...(but most of us already have a aftermarket wastegate..) and a stage 2 will allow higher rpm than stage 1....i cant remember how much...
you arent going to tune the ecm so i dont know what you mean by which is easier to tune...you might tune a wastegate or a boost controller...maybe even a fuel controller if you get one...but not the mopar computer...if you want to tune a computer you will want the aem engine management computer for like 2000 bucks...
Old Sep 4, 2007 | 02:17 PM
SRT4Greek's Avatar
SRT4Greek
Junior Member
the stage 2 kit raises redline from 6240 rpm to 6500 rpm...jus a bit better
i think its worth it..thats why im savin up
Old Sep 4, 2007 | 02:42 PM
PSI Chick's Avatar
PSI Chick
you guys aren't reading. he's not getting a s2 kit, just the ecu. for tuning purposes it doesn't really matter.
Old Sep 4, 2007 | 06:32 PM
T_U_R_B_O's Avatar
T_U_R_B_O
Yea psi got what i was saying lol... so ill be fine getting the stage 2 ecm with out the tip sensor and map sensor
Old Sep 4, 2007 | 06:34 PM
PSI Chick's Avatar
PSI Chick
yea it's perfectly fine
