aem uego
Old Sep 5, 2007 | 10:20 AM
MAssSrTdriven's Avatar
MAssSrTdriven
Default aem uego
can i just use the stock o2 housing when installing the eugo or is that a complete waste of time and i should just have the down pipe fabricated witha bung for the extra sensor
Old Sep 5, 2007 | 11:37 AM
PSI Chick's Avatar
PSI Chick
Default RE: aem uego
you need the wideband o2 sensor in the correct place, you can't just throw it anywhere
Old Sep 5, 2007 | 11:49 AM
Burnnout's Avatar
Burnnout
the o2 housing has nothing to do with installing the wideband...... you need an extra bung in your downpipe.
Old Sep 5, 2007 | 02:04 PM
BLKSRT4's Avatar
BLKSRT4
an wont it go right after the stock sensor
Old Sep 5, 2007 | 02:39 PM
Burnnout's Avatar
Burnnout
Either before or after is fine.
Old Sep 5, 2007 | 04:33 PM
PSI Chick's Avatar
PSI Chick
if you have a stage kit you can use the downstream o2 sensor bung for the wideband and just zip tie the o2 sensor out of the way.
