camber bolts ????
Old Oct 3, 2007 | 09:27 PM
zukidragon's Avatar
zukidragon
Default camber bolts ????
I am going to get the 1.6 front and the 1.8 rear lowering springs for my srt and was wandering if I will have to put camber bolts in the front
Old Oct 6, 2007 | 09:28 PM
Pressurecooker's Avatar
Pressurecooker
Default RE: camber bolts ????
Short answer. No not really.
Long answer. If you take it into an alignment shop, they might like to have them to really be able to dial you in, but in my experience, with only that much drop, there is very little camber change and the little bit more negative you may end up with, is probably more beneficial for handling with negligible effect on increased tire wear. I wouldn't sweat it, but if it causes you to lose sleep, by all means install them and get a pro alignment.
