stage 2 map and tip sensors
Old Oct 17, 2007 | 12:36 AM
hayOhitter's Avatar
hayOhitter
Default stage 2 map and tip sensors
If i buy stage 2 injectors and the map & tip sensors do i still need a new pcm to run the injectors?
Old Oct 17, 2007 | 01:00 AM
PSI Chick's Avatar
PSI Chick
Default RE: stage 2 map and tip sensors
the sensors have nothing to do with your ability to run the injectors. you need to be able to tune your fuel to run those, they're way too big for the stock system to handle.
Old Oct 17, 2007 | 01:33 AM
hayOhitter's Avatar
hayOhitter
how do i tune the fuel without buying the stage2 kit?
Old Oct 17, 2007 | 09:53 AM
PSI Chick's Avatar
PSI Chick
buy a fuel controller
