U110C-NO FUEL LEVEL BUS MESSAGE
Old Oct 28, 2007 | 02:15 AM
BLKSRT4's Avatar
BLKSRT4
Default U110C-NO FUEL LEVEL BUS MESSAGE
how the hell do i fix this?
Old Oct 28, 2007 | 12:44 PM
PSI Chick's Avatar
PSI Chick
Default RE: U110C-NO FUEL LEVEL BUS MESSAGE
reset your ecu and make sure your gauge cluster is on all the way
Old Oct 29, 2007 | 12:34 AM
BLKSRT4's Avatar
BLKSRT4
what is the point of that code?
Old Oct 29, 2007 | 09:26 AM
PSI Chick's Avatar
PSI Chick
it's a bus code, all U codes are. it means there's an issue with wiring. did you install a tt or alarm recently?
Old Oct 29, 2007 | 02:05 PM
BLKSRT4's Avatar
BLKSRT4
i tried to instal a TT but i took it out cause i had the wrong wiring. then i tapped everything off. is that bad?
Old Oct 29, 2007 | 04:24 PM
PSI Chick's Avatar
PSI Chick
no it's nothing. it's just usually that's when you see the bus codes. just make sure the cluster is on and reset it, it should go away.
Old Oct 29, 2007 | 11:10 PM
BLKSRT4's Avatar
BLKSRT4
it just went away this morning
Old Oct 29, 2007 | 11:52 PM
PSI Chick's Avatar
PSI Chick
cel's will stop lighting up on their own after a certain number of starts, doesn't mean the code is gone though. reset it just to be on the safe side.
Old Oct 30, 2007 | 02:13 PM
BLKSRT4's Avatar
BLKSRT4
alright
