new stage 2 ecu
Old Nov 26, 2007 | 01:35 PM
flamingpinhead's Avatar
flamingpinhead
Section Moderator
Default RE: new stage 2 ecu
dont really know, neither here nor back where im from in PA have smog testing of any kind
Old Nov 26, 2007 | 02:43 PM
PSI Chick's Avatar
PSI Chick
it will pass the smog test. inspections are done with odb now, as long as there's no codes it passes. i'm on s3 with no cat and i pass lol
Old Nov 26, 2007 | 02:47 PM
flamingpinhead
Section Moderator
S3 still passes, thats awsome. im not familiar with emissions testingother than you get an extra sticker in PA...how do they administer the test anyhow?
Old Nov 26, 2007 | 11:58 PM
PSI Chick's Avatar
PSI Chick
they plug a computer into the obd port and run some diagnostics. as long as there's no codes, you pass. shops still do a visual safety inspection, but no more rollers.
Old Nov 27, 2007 | 08:06 AM
Burnnout's Avatar
Burnnout
Huh.... that's easy to beat. I thought they used a sniffer.
Old Nov 28, 2007 | 11:14 PM
Moparmatt440's Avatar
Moparmatt440
Nice Im glad I just ordered the stage 2, I do have one question, say a shop did use rollers would a 50 trim pass with the stage 2 set up or would I just have to put the stock ecu back on?
Old Nov 28, 2007 | 11:31 PM
PSI Chick's Avatar
PSI Chick
as long as there's not codes and there's a cat on the car it should pass. s2 is a little borderline because it runs so pig rich, but with a fc on there it shouldn't be a problem. but it doesn't really matter, all cars newer than 1996 get obd now.
Old Nov 28, 2007 | 11:42 PM
dustyloins's Avatar
dustyloins
Hall of Fame Member
Down here, as long as your lights, brakes, and horn work, you're good to go for another year......[&:]
Dusty
